 Post subject: SEAGATE Problem
PostPosted: February 20th, 2008, 13:32
I have a ST3250823A drive with many bad bloc on one head.
I want to copy this drive under Data Extractor with map creating for disconnect this head.
I have this message : "Invalid CERT Disk code"
I use PC3000 UDMA Seagate Utilities for verify and I have the same message when I want to load CERT.
At this moment I can read sector on drive !
After I switch HDD to ATA mode (age=50) drive not ready and I have this message :
Not interface Age !
INVALID Cert Disk code - ROM resident Revision required : 3.03
Command Inactive - No valid Cert code Detected
T>
How can I restore sector access
Misioux
 Post subject: Re: SEAGATE Problem
PostPosted: March 6th, 2008, 4:27
HI, please try to
press ; to check in command mode to check the current age
SalvationDATA--Profesionnal Hard drive solution Provider. MSN: sales.laura@salvationdata.com
PostPosted: March 16th, 2008, 14:51
Hi Laura ,
You Are Advising About Seagate :ddown: ,you Support also sucks Big time .I Want a Replacement Soon ,And Hi misioux Just Search For Seagate Terminal Commends and a Door Of Possibilities will Open for You In Seagate .
PostPosted: March 17th, 2008, 14:45
Hi Laura and Amarbir.
Laura I appreciate your patience. And Amarbir I appreciate your Right of customer.
To Laura,
I am using PC3000-PCI original which got its power unit burned during warranty period. I have contacted ACE and they were very nice to change the part for free (repair and shipment). They asked me to Send it through DHL.
But These shipment Company is having so much hectic documents that I was unable to send it. I have to get it repaired locally.
Now I have a good solution for both of you.
1 Amarbir U send a faulty product to Laura Back but not indicating it as return after repair basis. This requires less paper. and put the value of product Less then Rs 5000/-. this will avoid custom hassle. (i have discussed in my case with some custom agents. they also say sending o returnable basis is hard.
Or try UPS cargo. they are less hectic then DHL. I have send 2 hard disk through them indicating For repair / Data recovery. No problem with this technique.
2. Laura U can send Amarbir the tool. which is fully tested.( I trust customer satisfaction). Send him as a new tool not as repaired or replaced. this can block his tool at Custom clearance. because for repaired or replaced they need 2-2-2 many documents.
I hope this will help u both.
And this forum also.
DF :)
DF :)
www.datatracksystem.net
cron
