| probe position to unlock HTS721 sata http://forum.hddguru.com/viewtopic.php?f=11&t=8576 |
Page 1 of 1 |
| Author: | imtra84 [ February 23rd, 2008, 19:42 ] |
| Post subject: | probe position to unlock HTS721 sata |
hello I want to know the probe position to unlock IBM HTS721 SATA 60GB 2.5 laptop HDD thanks |
| Author: | pepe [ February 26th, 2008, 11:47 ] |
| Post subject: | Re: probe position to unlock HTS721 sata |
Hi RdX and RdY. pepe |
| Author: | imtra84 [ February 26th, 2008, 21:37 ] |
hi what rdx and rdy |
| Author: | Doomer [ February 27th, 2008, 9:58 ] |
RDX and RDY are signals from preamp. Wires with these signals connected to R/W chip Usually you supposed to connect probe to RDX and RDY signals to messed up data from SA and prevent HDD to read password How probe should work: because you cannot just cut off all data from preamp (drive will shut down R/W system and you will not be able to work with SA after) the probe is constructed as a filter. This filer supposed to pass through low-frequency servo-signals and cut off high-frequency SA data That means you need unique probe/filter for each type of preamp and R/W channel. As I know AceTeam didn't create probes for new IBM/Hitachi drives, so that could be a loooong love with a new drive Enjoy |
| Author: | Deppe92 [ December 1st, 2008, 12:26 ] |
Anyone knows the probe position for HTS721 P-ATA? I need to unlock HTS721060G9AT00 using PC3000PCI original (not UDMA). |
