 Post subject: LDR ?
PostPosted: March 27th, 2008, 4:02
Hello and thanks in advance for any help. Can someone please point me to where I can get the correct firmware for this drive and utility needed to program it?
The drive is a slim, 40gb Maxtor DiamondMax Plus 8 and the following is on the label:
6E040L0510653 <== model #?
K,M,G,A
code: NAR61590 <==firmware revision?
s/n: E1A1XL5E
Drive is from a Dell Optiplex GX260 computer.
BIOS detects it as N40P and "drive fail" error occurs.
It powers up, spins, and there is no clicking noise whatsoever so I imagine a firmware fix can bring this drive back to life.
Thanks again, your help is much appreciated.
 Post subject: Re: LDR ?
PostPosted: March 27th, 2008, 7:48
http://www.acelaboratory.com/ :!:
Data Recovery Ireland
PostPosted: March 27th, 2008, 15:52
You need professional help if you need the data.
If you don't need the data, bin the drive.
cron
