Problem with UDMA
http://forum.hddguru.com/viewtopic.php?f=11&t=8861
Author:  dobrevjetser [ April 18th, 2008, 3:52 ]
Post subject:  Problem with UDMA
Hi Friends,
My PC3K UDMA behaves strange!
All is fine when just one drive is attached, but as soon as i attach a drive to the second channel and power it, the drive on the first channel starts to click.
I can read some data, then it clicks again after a few seconds, i can read again etc ...
If i power the second drive down, no problem at all.
Anyone who also experienced this ?
I suspect a problem with the powerboard.
Dobre
Author:  darkforce1 [ April 18th, 2008, 3:57 ]
Post subject:  Re: Problem with UDMA
Change your SMPS (power Supply Unit).
This happens when your power supply is not working fine.
I recommend at least 600Watt SMPS. Coolermaster/ Antec/ Vantec.
DF :)
Author:  dmarques [ April 18th, 2008, 7:58 ]
It's better, as I never had problems with UDMA like that.
Author:  Shortscurcuits [ April 28th, 2008, 0:40 ]
Some newer power supplies have short circuit protection incorporated into v-reg, my main rig for drive recovery started having the same problem after I had to replace the power supply with an emergency backup after a power surge. I used to be able to change drives hotswap in XP, but now it bluescreens from the voltage drop when a new drive is plugged in.
