 Post subject: HTS541--- need password removal
PostPosted: May 6th, 2008, 18:26
Hi guys i got HTS541---J-- DRive need pw removal using pc3kUDMA ...
when i try to do that a pic comes up which shows short pin 4 and 5 but the text written beside it says short pin 5 and 6 can anyone correct that. will be helpful.... just to be certain nvram on this pcb is U6
thanks
 Post subject: Re: HTS541--- need password removal
PostPosted: May 7th, 2008, 4:01
You're on the right way.
PostPosted: May 7th, 2008, 6:51
SO THEN which way is right short 4 and 5 or 5 and 6 ?
PostPosted: May 7th, 2008, 13:58
Hi
NV ram
5-| |-4
6-| |-3
7-| |-2
8-| .|-1
if the the disk is ide then put the disk in safe mode and UDMA will do it by itself. But in case of SATA. u have to remove the PCB when asked. SHOT the 4 - 5 PIN. Press ok when ready. after then put the PCB back on hard disk and Press ok when ready.
Password Gone.
DF :)
DF :)
www.datatracksystem.net
PostPosted: May 11th, 2008, 10:02
Thanks DF ... I will try right away ...
PostPosted: May 19th, 2009, 9:44
HDDTECH,
did you succeed to clear the password
PostPosted: May 24th, 2009, 16:43
this is fairly straighforward when using PC3K UDMA. Let us know if this was successful.
PostPosted: August 24th, 2009, 6:02
Maybe someone can help me with this. I also tried to remowe password from HTS541 (SATA, 2.5inch) and have the same problem. Picture shows to short pins 4-5 and the message says 5-6. However, i tried both ways and failed. I tried to 'operate' on PCB but after shorting pins and pressing OK i get error message 'you might have shorted NV-RAM incorrectly'. I also tried to solder wires on pins so i can short it while PCB is mounted on drive but the result is the same.
Does anybody have any suggestion?
PostPosted: August 24th, 2009, 23:19
hi all,
i had success for IDE.
data recovery service[/b]
