| HTS541--- need password removal http://forum.hddguru.com/viewtopic.php?f=11&t=8958 |
Page 1 of 1 |
| Author: | HDDTECH [ May 6th, 2008, 18:26 ] |
| Post subject: | HTS541--- need password removal |
Hi guys i got HTS541---J-- DRive need pw removal using pc3kUDMA ... when i try to do that a pic comes up which shows short pin 4 and 5 but the text written beside it says short pin 5 and 6 can anyone correct that. will be helpful.... just to be certain nvram on this pcb is U6 thanks |
| Author: | dmarques [ May 7th, 2008, 4:01 ] |
| Post subject: | Re: HTS541--- need password removal |
You're on the right way. |
| Author: | HDDTECH [ May 7th, 2008, 6:51 ] |
SO THEN which way is right short 4 and 5 or 5 and 6 ? |
| Author: | darkforce1 [ May 7th, 2008, 13:58 ] |
Hi NV ram 5-| |-4 6-| |-3 7-| |-2 8-| .|-1 if the the disk is ide then put the disk in safe mode and UDMA will do it by itself. But in case of SATA. u have to remove the PCB when asked. SHOT the 4 - 5 PIN. Press ok when ready. after then put the PCB back on hard disk and Press ok when ready. Password Gone. DF |
| Author: | HDDTECH [ May 11th, 2008, 10:02 ] |
Thanks DF ... I will try right away ... |
| Author: | mindsparc [ May 19th, 2009, 9:44 ] |
HDDTECH, did you succeed to clear the password |
| Author: | hddguy [ May 24th, 2009, 16:43 ] |
this is fairly straighforward when using PC3K UDMA. Let us know if this was successful. |
| Author: | Aleksandar [ August 24th, 2009, 6:02 ] |
Hi, Maybe someone can help me with this. I also tried to remowe password from HTS541 (SATA, 2.5inch) and have the same problem. Picture shows to short pins 4-5 and the message says 5-6. However, i tried both ways and failed. I tried to 'operate' on PCB but after shorting pins and pressing OK i get error message 'you might have shorted NV-RAM incorrectly'. I also tried to solder wires on pins so i can short it while PCB is mounted on drive but the result is the same. Does anybody have any suggestion? |
| Author: | networkpc3000 [ August 24th, 2009, 23:19 ] |
hi all, i had success for IDE. |
