| ST3500630A Error: ERR App Code incompatible SFL code http://forum.hddguru.com/viewtopic.php?f=11&t=9141 |
Page 1 of 1 |
| Author: | dobrevjetser [ June 4th, 2008, 10:43 ] |
| Post subject: | ST3500630A Error: ERR App Code incompatible SFL code |
Hi, After a head swap on a Seagate 7200.10 ST3500630A i get the following in the terminal: 4096k x 32 DRAM GALAXY - 1_Disk S-6D 09-22-06_15:48 Buzz HM SFI ! ERR Read App Code Then i try to read the code using the terminal commands, and this gives: F>R Code - A6 Track 15CC4.0.238 Sns FFF F>j ERR App Code incompatible SFL code I tried with different boards, but i always get the same SFL error. Anybody who can help ? Thanks in advance, Dobre |
| Author: | Doomer [ June 4th, 2008, 11:03 ] |
| Post subject: | Re: ST3500630A Error: ERR App Code incompatible SFL code |
Application code has read errors or PCB is not original |
| Author: | TerraNova [ June 4th, 2008, 21:48 ] |
ERR Read App Code from my experience is incompatible preamp |
| Author: | dobrevjetser [ June 5th, 2008, 3:54 ] |
I used an identical drive, same partnr, same site code. Only difference is patient has FW 3.AAD and donor 3.AAE but that should not be the cause. Dobre |
| Author: | Doomer [ June 5th, 2008, 12:43 ] |
dobrevjetser wrote: I used an identical drive, same partnr, same site code. Only difference is patient has FW 3.AAD and donor 3.AAE but that should not be the cause. Dobre Did you write original ROM into donor's PCB? |
| Author: | dobrevjetser [ June 5th, 2008, 13:17 ] |
Hi Doomer, I use the original PCB, since that has no problems. However, this disk has been with another company before, and there is the writing "SPARE 160" on it. So i guess they changed the pcb. I'm contacting my client so he can ask for the original pcb. Dobre |
| Author: | suntom [ October 4th, 2008, 4:48 ] |
dobrevjetser wrote: Hi, After a head swap on a Seagate 7200.10 ST3500630A i get the following in the terminal: 4096k x 32 DRAM GALAXY - 1_Disk S-6D 09-22-06_15:48 Buzz HM SFI ! ERR Read App Code Then i try to read the code using the terminal commands, and this gives: F>R Code - A6 Track 15CC4.0.238 Sns FFF F>j ERR App Code incompatible SFL code I tried with different boards, but i always get the same SFL error. Anybody who can help ? Thanks in advance, Dobre sway bios to new boards maybe you sway wrong head to bad-disk |
| Author: | shahij [ October 1st, 2013, 6:19 ] |
suntom wrote: dobrevjetser wrote: Hi, After a head swap on a Seagate 7200.10 ST3500630A i get the following in the terminal: 4096k x 32 DRAM GALAXY - 1_Disk S-6D 09-22-06_15:48 Buzz HM SFI ! ERR Read App Code Then i try to read the code using the terminal commands, and this gives: F>R Code - A6 Track 15CC4.0.238 Sns FFF F>j ERR App Code incompatible SFL code I tried with different boards, but i always get the same SFL error. Anybody who can help ? Thanks in advance, Dobre sway bios to new boards maybe you sway wrong head to bad-disk dobrevjetser wrote: Hi, After a head swap on a Seagate 7200.10 ST3500630A i get the following in the terminal: 4096k x 32 DRAM GALAXY - 1_Disk S-6D 09-22-06_15:48 Buzz HM SFI ! ERR Read App Code Then i try to read the code using the terminal commands, and this gives: F>R Code - A6 Track 15CC4.0.238 Sns FFF F>j ERR App Code incompatible SFL code I tried with different boards, but i always get the same SFL error. Anybody who can help ? Thanks in advance, Dobre I have same output in Terminal after issueing R and j, produces same output like yours. PCB is original. How to resolve this? I have same T |
