| disconnect head 0 on WD1600BB http://forum.hddguru.com/viewtopic.php?f=11&t=9217 |
Page 1 of 1 |
| Author: | imtra84 [ June 13th, 2008, 20:36 ] |
| Post subject: | disconnect head 0 on WD1600BB |
hello, I have WD1600BB-00GUC0 with 0 head defective,I tried to disable it but after disabling it drive can't read or write SA tracks. I found this problem in disconnecting head 0 on this family only in WD drives. for example WD1600BB-00GUC0 has 4 heads from 6 when I disconnected head 0 there is 3 heads from 6 the worked heads is 1 4 5 but drive hanged when logged in pc3000 WD program or salvationdata WD doctor |
| Author: | harddrivespecialist [ June 13th, 2008, 21:59 ] |
| Post subject: | Re: disconnect head 0 on WD1600BB |
In this family you can disconnect any heads, except head 0 and 1 . |
| Author: | imtra84 [ June 13th, 2008, 22:09 ] |
why this family certinely |
| Author: | rameez [ June 15th, 2008, 7:10 ] |
Because this is the head that reads the SA . |
| Author: | imtra84 [ June 16th, 2008, 4:37 ] |
but u can disconnect head 0 in any WD hdd and make head 1 the first head |
| Author: | rameez [ June 23rd, 2008, 10:49 ] |
how just by editing head map or is there any other procedure ? |
