 Post subject: Can not delete or create patition maxtor 6Y080L0?
PostPosted: July 13th, 2008, 10:38
:?: Hi everyone
I have a Maxtor 6Y080L0 . I have checked all modules and all it right
And It don't have bad sector.But i can't delete patition or create new patition.
Everyone can help me?
Thanks a lot
 Post subject: Re: Can not delete or create patition maxtor 6Y080L0?
PostPosted: July 14th, 2008, 4:49
Everyone don't know about this problem
PostPosted: July 14th, 2008, 5:10
Must to know more about this case....
Did you check the MBR protection in BIOS?
Did you try to overwrite the MBR from Linux?
Regards,
Janos
PostPosted: July 14th, 2008, 9:40
what can i do for overwrite mbr from linux ?
PostPosted: July 14th, 2008, 12:52
dd if=/dev/[DEVICE] of=mbr-backup.bin bs=1K count=1
This is for backup
dd if=[1k file, what you want] of=/dev/[DEVICE] bs=1K count=1
This is for overwrite.
sync
Thats all.
PostPosted: July 15th, 2008, 2:06
Thanks N.C
can you speak specific? I can't understand your idea.
PostPosted: July 15th, 2008, 5:56
Yes, but need some more info.
If you boot to linux, post the dmesg output!
symple type to the prompt with root: "dmesg"
or dmesg | less
Alternatively you can watch this by this way also: cat /var/log/dmesg | less
(dd's if parameter is input file of is output file. (file, or device).)
Janos
