| Can not delete or create patition maxtor 6Y080L0? http://forum.hddguru.com/viewtopic.php?f=11&t=9399 |
Page 1 of 1 |
| Author: | htavu [ July 13th, 2008, 10:38 ] |
| Post subject: | Can not delete or create patition maxtor 6Y080L0? |
I have a Maxtor 6Y080L0 . I have checked all modules and all it right And It don't have bad sector.But i can't delete patition or create new patition. Everyone can help me? Thanks a lot |
| Author: | htavu [ July 14th, 2008, 4:49 ] |
| Post subject: | Re: Can not delete or create patition maxtor 6Y080L0? |
Everyone don't know about this problem |
| Author: | N.C. [ July 14th, 2008, 5:10 ] |
Hi, Must to know more about this case.... Did you check the MBR protection in BIOS? Did you try to overwrite the MBR from Linux? Regards, Janos |
| Author: | htavu [ July 14th, 2008, 9:40 ] |
what can i do for overwrite mbr from linux ? |
| Author: | N.C. [ July 14th, 2008, 12:52 ] |
htavu wrote: what can i do for overwrite mbr from linux ? dd if=/dev/[DEVICE] of=mbr-backup.bin bs=1K count=1 This is for backup dd if=[1k file, what you want] of=/dev/[DEVICE] bs=1K count=1 This is for overwrite. sync Thats all. |
| Author: | htavu [ July 15th, 2008, 2:06 ] |
Thanks N.C can you speak specific? I can't understand your idea. |
| Author: | N.C. [ July 15th, 2008, 5:56 ] |
Yes, but need some more info. If you boot to linux, post the dmesg output! symple type to the prompt with root: "dmesg" or dmesg | less Alternatively you can watch this by this way also: cat /var/log/dmesg | less (dd's if parameter is input file of is output file. (file, or device).) Janos |
