| Hitachi not loading open module error http://forum.hddguru.com/viewtopic.php?f=11&t=9438 |
Page 1 of 1 |
| Author: | HDDTECH [ July 18th, 2008, 12:18 ] |
| Post subject: | Hitachi not loading open module error |
HI all need help on this problem... when i hook up my drive to pc3k... it do not intialize but when i choose its family it comes up and gives me error open module not open ..... and i know with out open module u can not intialize this thing... i will appreciate any clue to fix this problem thanks |
| Author: | Daisy Woo [ July 19th, 2008, 18:00 ] |
| Post subject: | Re: Hitachi not loading open module error |
If the drive is one of the HSS541, HTS721or other new series then this is a common problem. Pc3000 does not allow writing to factory copy of modules and the problem is usually within the PSHT (P-List). Double check by looking in the modules list and check all modules. I've been doing a lot of development on these drives, and whilst I can now write to the factory modules, getting the drive to come ready still eludes me I dont give up though. |
| Author: | HDDTECH [ July 21st, 2008, 12:59 ] |
Yes that is right ... it is HTS721drive .. you did describe the problem right... so any solution i can try to solve it or call it quit |
| Author: | suntom [ October 4th, 2008, 4:41 ] |
HDDTECH wrote: HI all need help on this problem... when i hook up my drive to pc3k... it do not intialize but when i choose its family it comes up and gives me error open module not open ..... and i know with out open module u can not intialize this thing... i will appreciate any clue to fix this problem thanks maybe NVRAM is wrong ,maybe RSVD and USAG is lost |
| Author: | harddrivespecialist [ October 4th, 2008, 11:52 ] |
What is a model of the drive? Which PC3000 version are you using? |
| Author: | HDDTECH [ October 16th, 2008, 14:02 ] |
moDEL # hts721 SERIES 100GB ...USING PC3K UDMA IT IS THE NEWER VRSTION ... ANY HELP WILL BE APPRECIATE |
| Author: | msurgeon [ October 16th, 2008, 14:18 ] |
Did you try to start using "Load resources from..." either profile or database of similar disk? This should allow you to check SA condition. Let me know what you find. |
