HDD GURU FORUMS
http://forum.hddguru.com/
loading CERT with seagate drives
http://forum.hddguru.com/viewtopic.php?f=11&t=9632
Page 1 of 1
Author:  continuum [ August 12th, 2008, 20:49 ]
Post subject:  loading CERT with seagate drives
I am trying to recover data by using a heads map with a seagate drive.
When I try to make a heads map using PC3000, it gives a warning that CERT has to be loaded to HDD RAM for it to do this.
Will this damage data in any way or affect the recovery of data? I cannot see this in any of the manuals.
I have the older PCI PC3000 (not UDMA).
Author:  darkforce1 [ August 13th, 2008, 11:00 ]
Post subject:  Re: loading CERT with seagate drives
This is normal process. no need to panic. Go ahead. and purchase the original as soon as possible,
DF :)
http://www.phpbb.com/
