 Post subject: What is the Seagate Utility in PC-3000 good for? Nothing?
PostPosted: May 14th, 2008, 8:59
Hi All,
I own a PC-3000 UDMA and used to have a PC-3000 PCI for a couple of years. Other than password removal i never found any reason to use the PC-3000 to troubleshoot or repair hard drive problems.
I mainly use my PC-3000 for Firmware problems with Maxtor and WD hard disks. I have unlocked a few password protected Seagte disks but in find the PC-3000 very hard to use for the Seagate utility.
Most of the time when i get a Seagate hard disk which is faulty the drive powers up, detectes but reports UNC errors/bad sectors and using Data Extractor i copy any critical files i can if possible. Otherwise the Terminal mode has not been easy to learn and i have not found the ways to 'repair' a drive as i have not found any Segate HDD with a need to repair the firmware as far as i know.
My question is, from your experience - what kind of problems can the PC-3000 be used for with Seagate drives?
Thanks,
Zed.
 Post subject: Re: What is the Seagate Utility in PC-3000 good for? Nothing?
PostPosted: May 14th, 2008, 18:30
Hi Zed,
Agreed, Acelab did not make user friendly manual for Seagate.
Seagate drives 95% heads, media problem, so you can see that
opportunity for FW repair very small with this drives.
However, there are some method for starting Seagate from "Safe Mode",
and also some opportunity for clearing SMART when SA media is still good.
Mostly PC3000 for Seagate (and any Rx Tx device and program) is very useful
for diagnostics to determine faults.
Lately I notice that Seagate slims develope media faults in SA mostly Vendor Track
and mostly in SMART sectors.
Success!!
PostPosted: May 15th, 2008, 6:01
coffeebean, in the cases you have used he PC-3000 to 'repair' a Seagate disk and recover the data, what features did you use?
Was it a terminal command to 'clear smart' or something like this? I have read the PC-3000 manual and tried many times.
For example, the one you had with bad sectors in the SA, how did you find this out? (i.e what command did you use in PC-3000's Seagate tool?) and how did you fix this?
I don't explain you to teach me everything, i'm simply looking for an example of the kind of problem that can be fixed.
For example, i have had a Seagate IDE 3.5" HDD with suspected bad heads (i.e lots of UNC errors reports, cannot copy the files and DE cannot see the folder structure and the drive makes a ticking sound (like a clock's seconds ticking) as it's attempting to re-try reading sectors. This was sent to 'Seagate Data Recovery', they told the client it was a head problem but when it came back the drive's label was not even removed or peeled back. So i suspect either it was a PCB problem or a firmware related problem. I know this as my client told me about this and i looked at the disk to confirm.
So i suspect some of these 'suspected head problems' with Seagate drives may actually be able to be solved in other ways.
Thanks coffeebean .
Zed
PostPosted: May 15th, 2008, 7:09
Seagate is just some of complicated drive
I think before we try to run more deeply in seagate drive. there is lot of seagate variable need to be understand Not just LEVEL Command. but All this variable still have no description. even there is a manual of ALL LEVEL command. Without understand ALL the variable, and fully description of the variable manual will be useless.
such :
physical Cyl VS Gray Cylinder
MUX Variable
NIWOT variable
Adaptive Data variable
MR HEad Bias Varible
and still so many variable.
and the most important one is how we understand the Log come out from the terminal report.
Спасибо
СУТИОНО / АПИНГ
PostPosted: June 3rd, 2008, 13:41
yes and another the way to access sectors and zones called "Niwot" acess to translate to LBA
Best regards
PostPosted: June 3rd, 2008, 15:41
zed,
did you use PC-3000 support?
Is it helpfull?
www.datarecoveryne.com
PostPosted: June 3rd, 2008, 21:53
unfortunately the support is not as I expected, Salvationdata support is excellent in my opinion.
PostPosted: June 3rd, 2008, 21:55
Yes, ace labs support is pretty crap. They usually only answer easy questions. any tricky questions are ignored or never responsed to in my experience. If they know the answer they are usually fast and helpful.
PostPosted: June 12th, 2008, 17:56
Hi Guys,
I have a PC3kudma, brand new, and i am having a problem with the SEAGATE MAXTOR disk off 1TB that appear 0MB in th bios.
i try to connect via com port, but the terminal it appers some "trash", also try that with a brand new disk the same size 1TB and also nothing new.
Anyone have any ideia how can i repair the service area and get the disk with 1TB.
Jose
ZeBong
" Россия еще раз"
PostPosted: June 14th, 2008, 7:09
drive is not supported yet.
PostPosted: June 15th, 2008, 7:48
Thanks terranova,
do you know a way to communicate with the disk ?
Jose
ZeBong
" Россия еще раз"
PostPosted: August 3rd, 2008, 11:11
zed wrote:
Hi All,
Thanks,
Zed.
write the fw to disk
only vendor,power off / on
the lock disk will unlock
PostPosted: August 25th, 2008, 19:28
zebong wrote:
Hi Guys,
Jose
You need to set the baud rate correctly (9600) - Try the different settings (F4) - most use 9600baud.
It's better to ask a stupid Question - than to make a stupid mistake
Luke Healey
Datalab Data Recovery
Hamilton
New Zealand
Users browsing this forum: No registered users and 128 guests
