Forum rules
 Post subject: Best Board to use for DDI?
PostPosted: March 13th, 2010, 9:01
Any ones user more than others? I fear the dell board im using at the moment may not be the best
any suggestions?
thanks
andy
Databusters Data Recovery Glasgow
http://www.datarecovery.co.uk/latest-data-recovery-jobs/
 Post subject: Re: Best Board to use for DDI?
PostPosted: March 13th, 2010, 9:48
Nvidia chipset based, I use Asus.
PostPosted: March 13th, 2010, 13:10
merci :D
PostPosted: March 17th, 2010, 2:24
fyi... i'm using a dell 5150 dimension and everything seems to work fine, especially since the 3.02+ upgrades.
PostPosted: March 17th, 2010, 10:45
thanks guys, get it in a couple of days so im getting stuff ready for it
thanks
andy
PostPosted: March 17th, 2010, 15:39
If I read the manual right, DDI comes with a compatible add in card, is there a draw back to using the card?
PostPosted: March 17th, 2010, 17:54
not that i know of -- in fact i think it makes the DDI more compatible, as long as you have a pci card slot, tho there may be a warning about some kind of specific motherboard in the manual. *i have the pci card version.
PostPosted: March 19th, 2010, 12:45
Hmm, the manual says:
Nvidia nForce: "works best with the DeepSpar Disk Imager."
Add in card: "works well with the DeepSpar Disk Imager."
Guru opinions?
PostPosted: March 19th, 2010, 13:06
This was the answer I just got from DeepSpar:
"There doesn’t seem to be a difference between NVIDIA chipset motherboard and the card we currently supply with every DDI"
PostPosted: July 23rd, 2010, 3:54
I don't use the PCI card as I find it slower than the motherboard directly.
I use the ASUS M3N78-VM
Users browsing this forum: No registered users and 48 guests
