Forum rules
 Post subject: Seagate ST31000528AS 7200:12 1TB Benchmarks and S.M.A.R.T.
PostPosted: February 27th, 2011, 0:10
Hi..
How Healthy is My 1TB , When I Bought 1TB , there was some sound coming mostly when seeking, i though it was defective, then i replaced with new one, This one also has the same sound..
why this happens, i think this is normal , I have the same sound with my Old 80Gb Seagate Sata I [ it's almost 7 years old running fine nw with sound], Which is louder than 1Tb, i think two platter Harddisks may produce this sound.... Check out this Youtube, someone has with the same sound....
http://www.youtube.com/watch?v=XWwr0FzOCA8
Benchmark Graphs
Error Scan
 Post subject: Re: Seagate ST31000528AS 7200:12 1TB Benchmarks and S.M.A.R.T.
PostPosted: February 27th, 2011, 6:33
that something to do with the heads seeking on the platter moving into postion
have you dropped the drive at all
and did you do a full format of the drive before use
seagate drives are crap they use to be good
but not anymore they fail more times then ibm deathstar
i got a 500gb with the same issue drive works fine and checks out fine no errors
PostPosted: February 27th, 2011, 7:07
No i didn't drop at all, like i said first drive has these sound, so replaced another drive immediately, this one also has got the same scratching sound, No first time when hooked , i have done a Full Format[slow Format] ..... don't know why this two Platter drives have these sounds[Especially From Seagates] From my 8 Years of Computer xperience, none of Seagate Drives Failed, I trust them.. I have Seagate 80GB SATA I Running till now.....
Users browsing this forum: No registered users and 17 guests
