Forum rules
 Post subject: i want to change the physical Serial Number of hdd...
PostPosted: November 11th, 2011, 17:48
I want to change The physical serial number for SAMUSUNG 40 GB harddrive... Model No: SV0412H
I have Opensuse operating system and a designing software installed on my orginal samsung hard drive SV0412H.
I had find the same Samsung Model SV0412H hard disk... but when i clone it from my original hard drive to other hard drive , the designing software start prompting serial KEY. Even the model number is same but serial number is different. But opensuse is properly running...
I am sure that Software had binded with my original Hard disk Serial number..
I want to change the serial number of Hard disk.
Can someone help me in this aspect...?
 Post subject: Re: i want to change the physical Serial Number of hdd...
PostPosted: November 12th, 2011, 3:00
Serial no. is stored on particular modules of firmware. You need special tools like pc3000udma to modify firmware.Contact Dr pro in your area.
PostPosted: November 12th, 2011, 4:00
Contact original software vendor for help. Or just reinstall the SW with your original key
PostPosted: November 12th, 2011, 16:14
Look for Vtool, Wcube, or a factory version of Hutil.
PostPosted: November 12th, 2011, 17:33
What do you mean by DR.pro??
PostPosted: November 13th, 2011, 6:58
Data Recovery professional company
