Forum rules
 Post subject: Interpreting Samsung HDD Terminal Output
PostPosted: February 13th, 2018, 23:19
Hello, hddgurus. Excuse me for my English, I'm good in reading but not in writing.
I have some Samsung HDD, which has clicking of the death.
I connected to its Serial Diagnostic Port and have this messages:
[SHOS2:|.▒". HPC:33607398*PA VID=0007 PN=0000 Rev=0004
*PA VID=0007 PN=0000 Rev=0 004
PSL
U
S_0Shock Sensor Circuit Enabled
SO_1
Init RPM=0
IS=6
CLA #36/101
Handoff RPM=503
SPOK
mS1 00000003
A1O=5 A1G=437
O=511 S=4
***** VCM is stucked : status 1
SoUL!
Abnormal end
PK_3 C: 0 H:0
A1O=5 A1G=438
O=511 S=2
Repeat few times
***** VCM is stucked : status 0
SoUL!
Abnormal end
PK_3 C: 0 H:3
Unlatch Fail
Software unloading!
PK_4 C: 0 H:0
Software unloading!
PK_4 C: 0 H:0 (Here HDD stops to try moving heads)
LED 110B (Repeat every second)
Then we opened HDD to view a VCM. There was some small lever, that should open a pass (it try to) for heads. But it can not do this and as following it stuck heads.
So, I just pushed it a little bit, so heads can move on. After that I had this output from serial terminal:
PSL
U
SO_1
Init RPM=0
IS=4
CLA #36/108
Handoff RPM=493
SPOK
mS1 00000003
A1O=5 A1G=422
O=511 S=4
Few tries before I pushed a lever
SoUL!
Abnormal end
PK_3 C: 0 H:3
A1O=5 A1G=428
O=511 S=2
SK C: 4605 H:0
Loaded FIT ( 0: 0: 1)
Reso Table Loaded
RRO1X Read OK
Overlay Code Loaded to 0x1004A000
FdtTable Loaded. Rev:0x01
| 19 | RLIST | 3 | 0 | 128 | 1140 |
| 19 | RLIST | 3 | 1 | 128 | 1340 |
| 19 | RLIST | 3 | 2 | 128 | 1140 |
Reading Serial Num Pass
Up MC
PwrOn RRO1x @ H0
Table) cos = 827904, sin = -144128
Coeff) cos = 6149, sin = 22083
DiskSlip : 77 [SrvTrk]
DiskSlip : 78 [SrvTrk]
PwrOn RRO1x @ H2
Table) cos = 827904, sin = -143104
Coeff) cos = -5950, sin = 82154
DiskSlip : 73 [SrvTrk]
TgtCyl: 842
Hd: 0 Zn: 0 Avg.:- 700
TgtCyl: 169771
Hd: 0 Zn: 1 Avg.: 2081
SVCAL(0080,0000)-->PASS
| 167 | DRM | 34 | 0 | 0 | 1140 |
| 167 | DRM | 34 | 1 | 0 | 1340 |
| 55 | SMRT | 19 | 0 | 3 | 1140 |
| 55 | SMRT | 19 | 1 | 3 | 1340 |
rb(e1140 19 0 3 12)
rb(e1340 19 1 3 12)
W-MC e(00001140) (19: 0: 3:0x09:0x0037)
rb(e1140 34 0 0 159)
rb(e1340 34 1 0 159)
W-MC e(00001140) (34: 0: 0:0x0B:0x00A7)
RecordValid Fail : 0107647D 0107E41D
SoUL!
PK_4 C: 8493 H:0
Software unloading!
PK_4 C: 8493 H:0
LED 1A04 (Repeat every second)
Can someone explain this output? Thank you very much.
 Post subject: Re: Interpreting Samsung HDD Terminal Output
PostPosted: February 14th, 2018, 2:20
Heads are suspect IMHO, probably damaged when stuck or when you released them.
PostPosted: February 14th, 2018, 3:34
I would shine up the HDA contacts with a soft eraser just as a precaution.
The drive failed to read 3 copies of the RLIST on heads 0, 1 and 2. The RLIST module is the list of reallocated defects. The drive also failed to read two (all?) copies of the DRM and SMaRT modules.
Samsung Modules List :
http://www.hddoracle.com/viewtopic.php?f=44&t=1175&p=5283
You may be able to clear/rewrite the RLIST (aka ALIST) by following this thread:
viewtopic.php?f=1&p=240389
PostPosted: February 27th, 2018, 1:07
Thank you for your answers.
No, I'm not even 1% sure that heads are not defective. But it moving normal when I remove "stucking condition". And I was as gentle as possible.
I think first of all we should replace a heads. We are looking for recepient now.
PostPosted: February 27th, 2018, 4:45
Well,
All youtube videos look so easy .IMHO always change to new heads after releasing heads as i have seen very few heads that look kinda ok under a scope after removing headstuck condition
