Forum rules
 Post subject: How can I edit MBR hex code so that grub only boots UEFI.
PostPosted: August 6th, 2020, 4:21
I tried looking up some documentation but they are so limited.
It's a really long story why i need this so if anybody knows please help me. Don't ask me why otherwise please.
So this iso boots both UEFI and legacy but i want to destroy its ability to boot BIOS. I burn the iso to HDD btw.
I just need to know how UEFI is different than BIOS in terms of MBR structure.
 Post subject: Re: How can I edit MBR hex code so that grub only boots UEFI
PostPosted: August 6th, 2020, 17:41
UEFI doesn't use the MBR code for booting. Instead it searches for a boot partition. Therefore you should be able to write zeros to the MBR without affecting a normal UEFI bootup. I don't know how GRUB fits in, though.
Someone please correct me if I'm wrong.
PostPosted: August 16th, 2020, 6:41
Late thanks, filling with zeroes does work.
dd if=/dev/zero of=/dev/sdX bs=446 count=1
example
dd if=/dev/zero of=/dev/sda bs=446 count=1
