Forum rules
Post new topic Reply to topic  [ 87 posts ]  Go to page Previous  1, 2, 3, 4, 5
 Post subject: Re: WD MCU - No more...
PostPosted: Yesterday, 17:46
WebClaw wrote:
Original PCB. Original MCU. Normal plaintext baseline. Modified the SA structure being discussed, power cycled, and read the same area again.
=Encrypted
Are you saying that non-original 0x8003 makes all data scrambled?
This sounds impossible. AFAIK is not read by the drive and it's written only externally.
I can check it when I'm back at work but very likely you made a mistake somewhere during the test
PostPosted: Yesterday, 18:00
I can certainly recheck. I'll use Spyglass and the same Charger for comparison.
PostPosted: Yesterday, 22:08
Can you also modify the foreign 0x8003 module by changing the reported SATA capacity to the IDEMA standard? For example, for a 2TB model, change 3906963632 to 3907029168. Then see if the reported capacity does indeed change. If it does, then this will be additional confirmation that the drive makes use of this module.
See https://forum.hddguru.com/viewtopic.php?p=320999#p320999
PostPosted: Yesterday, 22:24
Doomer wrote:
2. On top of that initial SysTick value also need to be exact as it was during original keys generation (not sure how it's achieved).
Could this have something to do with it?
RT-02450 1/31/2019 10:04:28 AM
PostPosted: Yesterday, 23:44
I'll have my re-test tomorrow when I head into the office.
This makes the most sense to me:
MCU-held secret / state + SA-held drive-specific value / state -> correct decryption context
PostPosted: Today, 4:06
In module 0x8003,
For Charger it is 3906963632,
while for CaramelR 7200 it is 3907029168,
Charger is self encrypting while CaramelR 7200 is not.
Hope it helps.
MSM DATA RECOVERY
PostPosted: Today, 4:12
The reduced capacity is typical of 2.5" Passport and Elements models. I believe the intent is to prevent the host from accessing the SmartWare encryption key at the end of the user area.
Users browsing this forum: No registered users and 30 guests
