Forum rules
Post new topic Reply to topic  [ 111 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6
 Post subject: Re: WD MCU - No more...
PostPosted: September 8th, 2026, 1:54
https://dokumen.pub/qdownload/the-ultimate-quotable-einstein-course-booknbsped-9781400835966.html
Albert Einstein wrote:
Many things which go under my name are badly translated from the German or are invented by other people.
To George Seldes, compiler of The Great Quotations (1960), cited in Kantha, An Einstein Dictionary, 175
https://www.youtube.com/watch?v=QW_YM_cFUNI
PostPosted: September 8th, 2026, 12:00
Doomer wrote:
Are you saying that non-original 0x8003 makes all data scrambled?
This sounds impossible. AFAIK is not read by the drive and it's written only externally.
I can check it when I'm back at work but very likely you made a mistake somewhere during the test
I tested it
0x8003 and 0x8028 have no effect on drive's encryption
I took a Spyglass2UL and wrote the modules from a Charger - no effect on drive's encryption or capacity (not a surprise).
PostPosted: September 8th, 2026, 13:50
Mikippp wrote:
Capacity reduction works via a switch in module 02.
Simply change 80 to 00 in one place and the full disk capacity will be restored.
Mikippp
Tested on WD50NDZW-11A8JS1
>ROM version............................. : 00.0AA
>ROM F/W version......................... : 0000000A
>Overlay F/W version..................... : 00.0BA
>Servo F/W version....................... : 03.7B
Mikippp
PostPosted: September 8th, 2026, 14:14
Mikippp
It's at offset 0x46 in section 3. That was one of my candidates.
mod02dump.7z [3.46 KiB]
Downloaded 104 times
PostPosted: September 8th, 2026, 14:19
without research, merely supposition: when a true SED drive is locked by pw using the wd sw, the bridge must present something to the host for the user to be able to unlock it, and that's the vcd partition. It is likely read from the 'missing' area by the bridge in some way. But this area does not contain any info related to decryption keys, only the sw, most probably. Basically the 'who cares' type of info for me, there are lot more interesting things about these drives...
PostPosted: September 8th, 2026, 14:40
I now realise that this area is not important for data recovery purposes, but I'm still interested to see what's there. The interesting thing, at least for me, is that the VCD area that is hidden by the bridge is actually larger than the 65536 sectors that are hidden by the SATA HDD.
PostPosted: September 8th, 2026, 19:46
how do you know the size of the VCD area?
PostPosted: September 8th, 2026, 19:47
See my other thread.
PostPosted: September 9th, 2026, 2:03
@einstein9
I suppose you say it is not 1,2,3 because it is required to solder some micro tin wire to some of the MCU I/O pins
and the second part could be setting up the R/W operations
would you like to share the difficulties?
Just in case, thank you in advance
R.
PostPosted: September 18th, 2026, 0:29
I doubled checked the firmware that generates the CPU keys.
The drives makes a request to hardware entropy generation registers to generate random keys, each key is created separately.
The are 256 bytes of random data, creating 8 keys in total. All 8 are written to the CPU.
Only two keys are used for the encryption, these 2 are selected from the 8 based on CPU hardware state.
The keys don't leave the secure CPU ROM or SRAM (unless they are read through JTAG externally).
Conclusions
1. I find it hard to believe that module 0x8003 has any security information
2. If the keys are stored on the drive they should have been read through JTAG and written somewhere thus creating an intentional backdoor
3. The keys can be written to either system area or even to servo, to hide them
PostPosted: Today, 1:32
Conclusions
Sorry for the late reply here to your point here Doomer, i was busy with other issues..
Anyway, am sure some of all of you still have some doubts about this post and after thinking about i came up with following proposal [b]which is limited only for "Doomer" here[/b]
i respect his knowledge and am sure all members here respect his opinion and decisions.
Doomer, Am willing to send you one of those MCU locked drives but to make it even better here for you and everybody i could say now that:
Am able to turn off encryption from MCU itself and you can use any SATA compatible pcb to access the data, found the trigger finally which is even better for my proof of concept.
I will send you one or multiple drives as you prefer here (i cover the shipping to you anywhere), and all what you need to do is one thing (will PM you the details only)
and you will have One Week to test and make your research and verification and send me back my drive(s) healthy as you took it (you cover shipping back).
Once you verify, and here is my Request to you: You will acknowledge here on this forum + Acelab Forum that my research or whatever you will find is true.
I don`t need anything else except your word here in public and am ready whenever you are.
btw I will post here the Tracking of shipment in public for everyone to follow up.
Users browsing this forum: No registered users and 119 guests
