Forum rules
 Post subject: To RAID or not to RAID
PostPosted: October 9th, 2008, 16:54
I like the new WD Velociraptor drives... specifically the new 2.5" 300GB version.
I currently own two Raptors... the originaly 36GB and a later 150GB. I use the 150GB as my OS (Vista64) drive, and the other as my exclusive Photoshop scratch disk.
I typically open 350-600 mb Photoshop layered files. Photoshop is a pig for using HDD scratch space... and I am lately using up all of my 36GB for just that. Time for an upgrade. Storage space isn't a problem.... these days it's cheap. What I need is speed and reliability.
The Velociraptor is supposedly 35% faster than the Raptor... which is already fast. That's why upgrading to that seems like a logical step.
What I want to know is my options for speed.
I have heard a lot about RAID. I do have a built in controller on my motherboard... so it's an option. Am i potentially going to get better performance out of a modern pair of decently large drives running RAID-0 than the Velociraptor???
Looking for some educated opinions/recommendations.
THANKS!!!
 Post subject: Re: To RAID or not to RAID
PostPosted: October 9th, 2008, 16:57
A RAID 0 will give you a little performance boost. However, be aware you are at least twice as likely to lose data in a failure, so be sure to either back up like mad, or just use the array for scratch space.
PostPosted: October 9th, 2008, 16:59
Yes, I realize that a mboard failure would pretty much ensure i never see the contents of those drives again. But yes... mostly I am looking for scratch space only.
PostPosted: October 9th, 2008, 17:20
I found these benchmark tests... but not sure which one really represents the performance I am after.
These seem to show the Velociraptor a little weak compared to some others:
http://www.tomshardware.com/reviews/HDD ... 14-12.html
and http://www.tomshardware.com/reviews/HDD ... 14-11.html
While this benchmark shows it to be better:
http://www.tomshardware.com/reviews/HDD ... 14-10.html
PostPosted: October 9th, 2008, 18:13
Actually, it's not so much a MB failure, but a failure of either drive. The data is spread across both drives, so if you lose one drive, you lose all your data. If it's scratch space, it doesn't matter.
PostPosted: October 11th, 2008, 15:59
My 2 cents:
- speed, reliability and fault tolerance don't match with price.
- usually integrated mobo controllers are not performing at the top (cheap solutions)
- benchmarks are not reliable, too many variables at play.
Users browsing this forum: No registered users and 17 guests
