In-depth technology research: finding new ways to recover data, accessing firmware, writing programs, reading bits off the platter, recovering data from dust.
Forum rules
Hi, I'm new here, and need help.
November 14th, 2008, 12:13
But don't we all......
I have a Samsung SP0802N and need a schematic for the main board. Any ides where I can find one?
I put 16v through it by mistake and blow a SMC, the one to the left of the middle screw. looking at the drive with the spindle cable to the top.
So, can about help here?
TIA
Andy
Re: Hi, I'm new here, and need help.
November 14th, 2008, 12:22
Post a pic
November 14th, 2008, 12:35
OK, here goes.
In the main pic. you can see where it sits, just to the left of that PK screw, the bottom pic is the SMC. I think it could be a diode, maybe a votreg. Anyway, what do you think? I have just DLL Palo_SVC_Manual_Eng.pdf which is great, but, does not show any components.
November 14th, 2008, 12:46
Pic is blurry, but seems it is a power diode. You should be able to simply 'replace' this with one from a donor PCB, no need to worry about compatibility.
November 14th, 2008, 13:27
hello,
i am sure that is diode.
November 16th, 2008, 6:54
Thanks Guys, that's what I was thinking, Diode, will have a look through the c&^p I have as see if I have one, failing that I will pop over to RS, I doubt if Maplin would have one.
I'll let you all know if I fix the problem.
Andy :)
