Forum rules
 Post subject: HDD instead DVD burner
PostPosted: November 8th, 2009, 0:56
In a DVD Recorder (with IDE connector) Is it posible to replace the DVD with an HDD? Both has the same ATA IDE cable. What are the modifications needed in order to HDD works when I want to record a video. If someone knows a webpage with information about this topic please let me know, thanks
 Post subject: Re: HDD instead DVD burner
PostPosted: November 9th, 2009, 23:52
I don't know any webpage or information about your topic to tell you what to do but I can give you the trick: if you can find out how to use "File Manager", the program in Windows v3.1, to copy data from any source to your DVD-WR and at that time, you can find out what you need in your topic.
* Có ba thứ ngu dốt :
Không hiểu biết những gì mình đáng biết.
Hiểu biết không rành những gì mình biết.
Hiểu biết những gì mình không cần biết.
