In-depth technology research: finding new ways to recover data, accessing firmware, writing programs, reading bits off the platter, recovering data from dust.
Forum rules
HDD (SSD) with minimal writing errors
September 16th, 2008, 9:44
Hi.
I want a drive that makes minimal writing errors (writing from audio cd's and downloads). Should I get SSD or HDD in this case? Assuming that drive isn't being moved while writing, which would affect a writing HDD. Which brand should I choose? Also, does HDD speed affect error possibility?
I tried to google answers or info, but didn't find any. Is there no difference in general?
Thanks.
Re: HDD (SSD) with minimal writing errors
September 16th, 2008, 11:06
SSD is quite slow on write commands but fast on read commands. get yourself a decent HDD :O)
September 29th, 2008, 16:44
Traditional Solid State Disk (SSD) manufactured using DRAM or an in-memory filesystem (setting aside the computer memory as a virtual hard disk) are the quickest. SSD will absolutely screem with almost zero latency on random (and serial) access, but it comes with an absolute penalty: $$$$Price$$$$.
New Solid State Disk (Flash) manufactured using NAND-Flash cell technology are slower on writes, suffer write errors.
Grab yourself a Linux box, build tmpfs in memory, and watch audio conversion scream. You can copy from hard disk into tmpfs and out again at system boot/reboot or regularly.
