In-depth technology research: finding new ways to recover data, accessing firmware, writing programs, reading bits off the platter, recovering data from dust.
Forum rules
To RAID or not to RAID
October 9th, 2008, 16:54
I like the new WD Velociraptor drives... specifically the new 2.5" 300GB version.
I currently own two Raptors... the originaly 36GB and a later 150GB. I use the 150GB as my OS (Vista64) drive, and the other as my exclusive Photoshop scratch disk.
I typically open 350-600 mb Photoshop layered files. Photoshop is a pig for using HDD scratch space... and I am lately using up all of my 36GB for just that. Time for an upgrade. Storage space isn't a problem.... these days it's cheap. What I need is speed and reliability.
The Velociraptor is supposedly 35% faster than the Raptor... which is already fast. That's why upgrading to that seems like a logical step.
What I want to know is my options for speed.
I have heard a lot about RAID. I do have a built in controller on my motherboard... so it's an option. Am i potentially going to get better performance out of a modern pair of decently large drives running RAID-0 than the Velociraptor???
Looking for some educated opinions/recommendations.
THANKS!!!
Re: To RAID or not to RAID
October 9th, 2008, 16:57
A RAID 0 will give you a little performance boost. However, be aware you are at least twice as likely to lose data in a failure, so be sure to either back up like mad, or just use the array for scratch space.
October 9th, 2008, 16:59
rchadwick wrote:A RAID 0 will give you a little performance boost. However, be aware you are at least twice as likely to lose data in a failure, so be sure to either back up like mad, or just use the array for scratch space.
Yes, I realize that a mboard failure would pretty much ensure i never see the contents of those drives again. But yes... mostly I am looking for scratch space only.
October 9th, 2008, 17:20
I found these benchmark tests... but not sure which one really represents the performance I am after.
These seem to show the Velociraptor a little weak compared to some others:
http://www.tomshardware.com/reviews/HDD ... 14-12.html
and http://www.tomshardware.com/reviews/HDD ... 14-11.html
While this benchmark shows it to be better:
http://www.tomshardware.com/reviews/HDD ... 14-10.html
October 9th, 2008, 18:13
Actually, it's not so much a MB failure, but a failure of either drive. The data is spread across both drives, so if you lose one drive, you lose all your data. If it's scratch space, it doesn't matter.
October 11th, 2008, 15:59
My 2 cents:
- speed, reliability and fault tolerance don't match with price.
- usually integrated mobo controllers are not performing at the top (cheap solutions)
- benchmarks are not reliable, too many variables at play.
