Forum rules
 Post subject: WD3200JS-60PDB0 knocking help me
PostPosted: October 8th, 2008, 13:38
I have WD3200JS-60PDB0 nocking
i test it by PC-3000 in the kernel mode i read thes data
Techno mode key:
Tech on................................. : Ok
ROM:
ROM reading............................. : Ok
Heads configuration..................... : by map
Heads number............................ : 6
Heads number in use..................... : 6
Switched off heads...................... : No
Head map................................ : 0,1,2,3,4,5
who can explain how to get data from it or what is the work of the points on the pcb E16 e29 e26 ....
 Post subject: Re: WD3200JS-60PDB0 knocking help me
PostPosted: October 8th, 2008, 13:49
Heads are dead - 99%
PostPosted: October 8th, 2008, 13:58
and what is the 1%
PostPosted: October 8th, 2008, 14:16
can you gev me any information about the Points of the PCB E3 E16 E19 37
PostPosted: October 8th, 2008, 14:25
Hassan wrote:
and what is the 1%
0.5% is PCB and 0.5 is SA
PostPosted: October 8th, 2008, 14:27
sure
they are nice round pieces of copper covered with solder and connected to chips on PCB
and they marked with white paint
PostPosted: October 8th, 2008, 14:41
You assume that if you get information about some points on the PCB you will be able to fix drive
Your assumption is wrong and in this situation there is no point to provide you information about the points on the PCB
PostPosted: October 8th, 2008, 14:47
so what is the work of this points
PostPosted: October 8th, 2008, 14:50
Replace HSA or send it to a pro.
www.datarecoveryne.com
PostPosted: October 11th, 2008, 16:03
They are test points, what do you expect to read out at them? (assuming you have the proper equipment)
PostPosted: October 20th, 2008, 21:01
yes 0.5% PCB and 0.5% SA 99%head
PostPosted: October 20th, 2008, 21:19
E26 E19 and E26 GND 70C
PostPosted: October 20th, 2008, 21:20
HOO
PostPosted: October 21st, 2008, 15:20
HAA
PostPosted: October 22nd, 2008, 11:07
Did you manage to repair damaged HSA through the mentioned testing points??
If so, do you want a job? lol :lol: :lol:
