Forum rules
 Post subject: Hard Drive stand alone testers
PostPosted: November 25th, 2008, 13:06
Has anyone work on or seen a LOW BOY Hard Drive testers working
I am try to get one working to test SATA drives with no luck
Can Email photes if you need to see what one looks like
Many thanks for read and haveing a look
Hard drives from 10Mb to 2Tb MFM/RLL/SCSI/IDE/SATA/PATA/SAS
DRIVES / PCB / BOARDS
 Post subject: Re: Hard Drive stand alone testers
PostPosted: November 26th, 2008, 2:39
never heard of ?????????????
PostPosted: November 26th, 2008, 7:59
Some older equipment wont support SATA using a SATA/IDE adapter. Sometimes the SATA registers set IDX and if the equipment is waiting for 50h in the ATA register, it will wait until the cows come home.
Please show us the photo, as I havent heard of these nor can I find any info about them..
<itch>
https://www.mjm.co.uk/
PostPosted: November 26th, 2008, 10:14
What do you want the testers for? Just to check or to repair?
PostPosted: November 26th, 2008, 16:21
hello here is the photo of the tester this is the one that i am working on
It has 40 drive ports that are SATA / PATA they are fast load bays
each bay has 2 drive ports and has a PC to run that port and are linked by network cards
PostPosted: November 26th, 2008, 23:55
you might want to find out which type of sata drives your trying to use
as they are all diffrent. sata 1,2
the unit looks like its for only testing the drives before the factory release them.
other meaning its a soak test bench.
