Forum rules
 Post subject: Hitachi 5K250-120 Firmware reading/writing ?!
PostPosted: December 3rd, 2008, 19:12
I have a Hitachi HDD with 120 GB capacity which I want to read it's firmware in order to do some researches.
Its model number is : HTS542512K9SA00
I was wondering if there is any way that I could access to its firmware?
Thanks in advance
 Post subject: Re: Hitachi 5K250-120 Firmware reading/writing ?!
PostPosted: December 5th, 2008, 19:16
Well, to reach firmware level you require special tools or else a lot of knowledge.
You can't do it as easy as I think you would like.
PostPosted: December 6th, 2008, 8:48
Thanks for the heads up :wink:
It is technically possible to remove firmware chip from the board and read it using an external programmer?
PostPosted: December 6th, 2008, 8:56
There's no "firmware chip", only ROM and NVRAM chips.
The firmware is recorded on the platters in the SA (Service area). Only accessible with special (expensive) tools.
PostPosted: December 6th, 2008, 9:16
What would be best first of all would be reading something on this forum about SA and firmware level, so you can understand what is firmware and where it's located.
PostPosted: December 6th, 2008, 14:25
Firmware is not stored in a flash but recorded like files on the platter(s) so the external programmer is useless. NVRAM contains only adaptive data.
What are you trying to "research" ?!?
PostPosted: December 7th, 2008, 10:25
Thank to all of you for your answers.
I was curious about what's inside an HDD firmware and I wanted to do some crazy stuff :mrgreen:
Anyway I'll check the forum for more information.
PostPosted: December 8th, 2008, 11:03
That will prove to be a expensive venture for you for the sake of curiosity!
Users browsing this forum: No registered users and 100 guests
