Forum rules
 Post subject: SP0802N problem
PostPosted: December 5th, 2008, 9:13
my SP0802N had a metal key dropped on the pcb while it was powered up, the drive is no longer seen by the bios, before i try a data recovery company, i want to try and find a PCB and swap it over. Where is the best place to get a replacement PCB?
I have attached pics of the all 3 stickers on the drive.
Andy
 Post subject: Re: SP0802N problem
PostPosted: December 5th, 2008, 9:15
Nice Pics. You must match the Rom version.
PostPosted: December 5th, 2008, 9:27
How do i find the rom version and is there anywhere to buy replacement pcbs?
PostPosted: December 5th, 2008, 10:15
With your expierience and knowledge of HDD's and data recovery - trial and error. You could try ebay for PCB's.
PostPosted: December 5th, 2008, 12:04
Or get the patients ROM info over to the donor PCB.
Where are you based?
PostPosted: December 5th, 2008, 12:17
I'm based in the uk.
PostPosted: December 5th, 2008, 12:29
So am I.
PM me if interested in a recovery.
Cheers
Sean
PostPosted: December 5th, 2008, 14:06
I have the pcb u need but u better contact pcimage u will need to some other process as well as changing pcb .
PostPosted: December 16th, 2008, 0:53
write main code
