Forum rules
Post new topic Reply to topic  [ 29 posts ]  Go to page 1, 2  Next
 Post subject: 7200.11 Saga
PostPosted: January 21st, 2009, 10:09
From what I read on Seagate 7200.11 forums - the firmware problem only affects drives manufactured in Dec 2008 ????
Can this be correct? We have been seeing drives with similar symptoms (0 LBA, SMART and BSY) since July/Aug 2008 and probably before.
<itch>
https://www.mjm.co.uk/
 Post subject: Re: 7200.11 Saga
PostPosted: January 21st, 2009, 10:19
I have read elsewhere that drives after Dec 2008 are unaffected, and the 6 months previous to that are? and as there is around 1 million drives manufactured every month, that gives us 6 million drives with the fault potentially.
Maybe someone knows a more accurate figure??
PostPosted: January 21st, 2009, 10:21
how can I translate the date code? Ive just fixed one, I'll tell you when it was made.
PostPosted: January 21st, 2009, 11:16
http://www.lerti.fr/web/public/NoteTech ... -v1.01.pdf
PostPosted: January 21st, 2009, 11:49
i give up. 08381.
PostPosted: January 21st, 2009, 12:28
Data Code checker
http://www.bugaco.com/calculators/seagate_date_code.php
PostPosted: January 21st, 2009, 12:35
thanks doomer, it's been a long day.
right my lba 0 disk was made 2008 March 15th. I think we will see a lot more! woohoo.
PostPosted: January 21st, 2009, 14:17
HDD Spaz wrote:
i give up. 08381.
I make that 31 March 2008
<itch>
PostPosted: January 21st, 2009, 14:23
According to the document 0 day is the first Saturday from 1st July in yy - 1
So:
08381
YYWWD
yy-1 = 08-1 = 07 (2007)
Ist Sat in July 2007 is; the 7th
Weeks are next two figures ..
38 x 7 = 266 days
then add 1 day for the day of week = 267
so, 7th July 2007 + 267 Days = 31st March 2008 ???
Or do I need a new calculator ?
PostPosted: January 21st, 2009, 14:36
Scratchy, it's time to get a life. :wink:
PostPosted: January 21st, 2009, 14:51
What 7.00pm already ?
PostPosted: January 21st, 2009, 18:09
Maybe that is all Seagate can afford to repair at this time....
PostPosted: January 21st, 2009, 18:18
I wonder if the 7200.12 is just as SH1T ?
Should have stayed with the trusted Conner platform!
Trying to use the same code base thro all products is not going to be good.. Cheap but maybe you lose some inventivenes
PostPosted: January 24th, 2009, 14:05
Perhaps these were designed by ex Maxtor Dia Max 9 Engineers ?
Grrr
PostPosted: January 24th, 2009, 16:41
Nothing to do with Maxtor engineers. AFAIK
PostPosted: January 24th, 2009, 17:00
"time to market" pressure and demand for low prices are the cause of everything. You can make good products at a reasonable price and refer to a different target or build crap drives and sell "as-is", or put on the market unfinished products, and so on. The same old story. Really, no one need 1 TB drives on a 3,5" . It's the market that makes the "need" for it. Mostly, large drives are bought by end users to store emuled porn and warez and movies. What I still don't get is why people still rely on these time-bombs to store critical data. Again, welcome money.
PostPosted: January 26th, 2009, 11:29
My 7200.11 BUSY is of 2008 September 6th
PostPosted: January 26th, 2009, 11:38
Goldtiger,
Where are you based ?
PostPosted: January 26th, 2009, 11:43
Europe
PostPosted: January 26th, 2009, 12:02
I just sent a PM but depending on which country, there are probably several people on here that can help you.
<itch>
