Forum rules
 Post subject: WD Starling Head Disabling
PostPosted: January 30th, 2009, 9:47
I have a WD2500JB-00REA0 that clicks several times and powers down. I have entered Kernel mode and disabled head 5. disk now enters ready and can be identified. I have removed defects by head from appropriate head, cleared glist and recalculated translator based on plist alone, but disk still is not accessible.
Data is not important to me, I simply want to get the disk accessible again.
Am I missing something here?
 Post subject: Re: WD Starling Head Disabling
PostPosted: February 2nd, 2009, 0:46
It's a $40 drive. If you just want a working drive, that should still be under warranty.
PostPosted: February 3rd, 2009, 7:33
Hi! :mrgreen:
Used which tool and version? :?:
:idea:
Нет ничего невозможного
PostPosted: February 3rd, 2009, 11:53
This method won't work if zone table is different between heads. Sabres are OK. Hawks are not. Not sure about Starlings.
You can view Zone table in PC3000.
PostPosted: February 12th, 2009, 5:18
When vieweing Zone Table what am I looking for? Also can I modify this zone table to correspond with new head mapping of heads is disabled?
PostPosted: February 12th, 2009, 8:27
Why fix this drive? It's a WD, therefore a paperweight.
PostPosted: February 12th, 2009, 8:37
Starling vs "Starlings" :D
My Forum
PostPosted: February 12th, 2009, 9:47
Mr. Starling I suggest you do not repeat stuff after AceLab guys. It may turn they are not right
PostPosted: February 12th, 2009, 15:29
Have you formatted it with P-List?
I would rather do that myself
PostPosted: February 23rd, 2009, 12:57
What's your point?
You mean to say that Acelab guys are not sometimes wrong? I know that.
You mean to say that zone table is the same between the heads on all WD families? I know it's different on the newer families.
Or you mean to say this method of disabling heads does work on all WD drives? I think it does not.
