In-depth technology research: finding new ways to recover data, accessing firmware, writing programs, reading bits off the platter, recovering data from dust.
Forum rules
i\\bad problem need help from professional
March 26th, 2009, 10:37
i need help in recover data from bad wd800bb-00jhco
with bad pcb and i use hot sawap but i fount p list of hdd courpt and all module
Re: i\\bad problem need help from professional
March 26th, 2009, 13:56
what program are you using and what equipment are you using to access the SA to read your P list? Do you have PC3000 or what? Also can you post a copy of what you have here so people can see what you have found out. Might help a little to understand more. Sorry
March 26th, 2009, 19:42
Perhaps your hot swap didnt work...
March 28th, 2009, 13:18
i use pc3000
and still give errro
March 28th, 2009, 17:31
maybe wrong procedure ? why hotswap ?
March 29th, 2009, 6:34
You have bad pcb ?
