Forum rules
 Post subject: Abrapt power interuption - head parking
PostPosted: May 18th, 2009, 8:05
Since you guys make the disk nuts and bolts could you explain how the todays hard disk deal with the power interruption and the head stack parking?
Are they parked securely or not?
Eleana
 Post subject: Re: Abrapt power interuption - head parking
PostPosted: May 18th, 2009, 13:58
Spildit, you are partially right.
The drive can safely take out the heads, using the spinning platter's mechanical power, if the main power is down.
The only true is, if the main power is down during write cycle, the data may be will damaged.
Janos
PostPosted: May 18th, 2009, 14:32
Yes, this is correct.
If the external drive is "safe removed", than it is safe to turn of any time.
Janos
PostPosted: May 19th, 2009, 0:15
I have other balls that are telling me that these drives are delivering neverending problems...
Users browsing this forum: No registered users and 99 guests
