In-depth technology research: finding new ways to recover data, accessing firmware, writing programs, reading bits off the platter, recovering data from dust.
Forum rules
Please
do not post questions about data recovery cases here (use
this forum instead). This forum is for topics on finding new ways to recover data. Accessing firmware, writing programs, reading bits off the platter, recovering data from dust...
November 1st, 2009, 22:17
I installed a new WD5000SRL SATA II and now theres no display on my monitor when i turn my computer on. when i turn it on the hard drive speeds up and the Disk indicator flickers and makes noise like its working right, but theres no monitor display? whats wrong?
November 1st, 2009, 23:01
tried connecting the old HD that had display. same problem. maybe something wrong with the graphics card?
November 2nd, 2009, 12:44
Two options in this mater. One you have a graphic card problem, or two you have a memeory problem. May time when changing out material this can happen. Try to reset the memory and graphic card. If this does not help them you will need to change one or the other of them.
Hope this will help. Does not sound like a HDD problem sounds more like hardware problem in your mother board.
November 10th, 2009, 8:33
Does the display come up with HDD disconnected ?
November 10th, 2009, 16:41
to be able to help you, you need to explain your problem better.
What do you mean by saying "no display on the monitor"?
No post information or no windows information or noting at all?
