Forum rules
 Post subject: WD600BB-75CAA0 ticking!
PostPosted: January 12th, 2010, 11:04
Afternoon all,
I am having a bad day with a problematic Western Digital!
The HDD in question has been to another DR company who say that they have only swapped the PCB for a similar model and done nothing else. :?
The drive appears to have an electronics problem as the drive is not spinning up, nothing gets warm and PC3000 cannot see it in safe mode although I cannot see any damage to PCB.
I tried an identical PCB and the drive spun up with constant head ticking that doesn't stop (four ticks > short pause > four ticks > short pause etc.)
I swapped FW to new board and it does exactly the same thing.
Looking at the heads, they are in perfect condition, (Head0 - 41ohm; Head1 - 39ohm, Head3 - 39ohm) and the pre amp is fine.
The platter surfaces have no physical damage although I have not tried looking for magnetic corruption.
I don't have a great deal of experience with these older WD's so any assistance is appreciated - all I ever get to work on are classic bad heads, seized bearings (Seagate 1.5TB last week! :D ) and head crashes!!
Let me know if you want more details.
Thanks,
Tim
Timothy Ayers
Clean Room Engineer
http://www.palmerdata.com
Tel: +44 (0)20 7015 5380
 Post subject: Re: WD600BB-75CAA0 ticking!
PostPosted: January 12th, 2010, 12:04
what happens after hotswap?
PostPosted: January 12th, 2010, 12:23
PalmerData wrote:
I am having a bad day with a problematic Western Digital! Tim
I think I am having a Dejavu, I know exactly how you feel :roll:
You've got PM :mrgreen:
PostPosted: January 12th, 2010, 14:11
Annoyingly the new drive won't accept standby command, using either PC3000 or our in house tool.
I have now tried a new set of heads and it still does the same thing, the heads just bang continually! The new heads are back into the new drive and are still working ok.
I could tell the customer that it's a classic case of WD head alignment - they are getting used to hearing that! :wink: :wink:
Timothy Ayers
Clean Room Engineer
PostPosted: January 12th, 2010, 15:22
I think its an alignment problem. Considered outsourcing to a company that can deal with that issue?
PostPosted: January 12th, 2010, 15:33
im think had missalignment , can u check if reach Servo ? i had similar case if u want
Contact me on MSN
PostPosted: January 12th, 2010, 19:30
He has not replaced heads till now, at least did not mention. So alignment problem can be sorted out.
I would vote for preamp damage, though it might seem fine.
An MHA replacement would help with preamp..., but obvously it would raise some other problems :)
