Forum rules
 Post subject: Disk after flood - recovery
PostPosted: May 25th, 2010, 6:25
Have somebody recover disk after flood?
How you solved the problem. Or not?
Any curious case? ;)
 Post subject: Re: Disk after flood - recovery
PostPosted: May 25th, 2010, 7:56
Post some pictures.
ZeBong
" Россия еще раз"
PostPosted: May 25th, 2010, 8:03
I don't have such case. I'm just curious ;)
PostPosted: May 26th, 2010, 3:57
We had a large number of water damaged drives this year as a result of some bad flooding in our country. We successfully recovered approx 60% of them. We used a number of methods, some more successful than others. I was surprised at the volume of water that had ingressed into the drive, even on drives that were not submerged.
Also, we've handled a number of drives from CCTV DVR systems that were physically damaged and subsequently thrown into a river by criminals trying to destroy evidence. Got most of the footage off them, which was a nice result. Hopefully someone is sitting behind bars now :)
Data Recovery Ireland
PostPosted: May 27th, 2010, 8:57
Ok, one photo ;)
PostPosted: May 27th, 2010, 10:52
A good deal depends upon how long the water has been inside the drive. Oxidation begins rapidly and can cause permanent damage in short time.
PostPosted: June 3rd, 2010, 7:39
interesting how successful was the recovery of this drive how did you clean the other platters
would love to know more
PostPosted: June 3rd, 2010, 8:12
No success unfortunately. Heads are gone, massive platter destruction.
PostPosted: June 3rd, 2010, 8:16
sometimes it "May" be better to keep the drive damp before you do any cleaning.
Saying that I have only done one in my life time lol
PostPosted: June 3rd, 2010, 8:27
I think the main problem is not the water, but the rough conditions associated with flooding.
I agree with CK, about 60% or so seems reasonable recovery percentage for water damaged Hard Disks
PostPosted: June 6th, 2010, 11:12
water damaged drives successful ratio more then 70 to 80% depends on expereince..
Mostly easily fix :)
datarecovery trainer and harddisk repair professional
http://www.diskanalyzers.com
PostPosted: June 6th, 2010, 11:59
Well, the drive on the picture was a Quantum, so if heads were gone even if media was recovered to acceptable conditions, THIS was the biggest problem.
PostPosted: June 6th, 2010, 14:24
BlackST has right.
When is clean water it is "quite easy" to recover data, but what about slime?
