Forum rules
 Post subject: Clicking Soumd from hard drive during read and write.
PostPosted: October 11th, 2009, 4:51
I have a Seagate Barracuda Hard Drive of capacity 80 GB.From the time I switch on my computer and when I put my ear near the chassis of the computer I can hear a clicking noise from the hard drive and this happens in synchronization with the HDD light on the chassis.Is this normal or is there a fault with the hard drive ?
Drive Model # ST380215AS
 Post subject: Re: Clicking Soumd from hard drive during read and write.
PostPosted: October 12th, 2009, 13:21
If your drive work back it up and replace this drive. Simple - other wise risk the chance of loosing data all together
Iorana Haraharaini
PostPosted: October 13th, 2009, 9:17
Its common to hear a click with a lot of drives when you first power them on.
Zero Alpha: zeroalpha.com.au
PostPosted: October 24th, 2009, 9:43
you must check cable conection again, any problem or not, if no problem, that problem in your hdd
PostPosted: April 5th, 2010, 19:00
my hdd failed soon after this clicking, but i had been advised to copy you do same asap.
Users browsing this forum: No registered users and 88 guests
