Forum rules
 Post subject: smart monitoring is not available
PostPosted: June 27th, 2010, 15:32
I have this turned on in bios but it still doesn't work. Where do I go to get the controller drivers. I went on both the hdd and motherboard web sites but neither one of them had any updated drivers to download. In Device Manager I see (ide ata/atapi controllers) 2 IDE Channels and 1 Standard Dual Channel PCI IDE Controller are these the ones I should update? Can someone help find out what is wrong?
Vista
HDD: WDC WD16 00JS-22NCB1 SCSI Disk Device
MotherBoard: ELITEGROUP MCP61PM-AM 1.0
 Post subject: Re: smart monitoring is not available
PostPosted: June 27th, 2010, 16:56
I have tried many different smart monitoring software to check the condition of my hdd but they all report that smart monitoring is not available.
PostPosted: June 27th, 2010, 22:36
Your board appears to be using NVIDIA's MCP61P chipset.
It appears to have one Primary IDE socket plus four SATA connectors:
http://support.gateway.com/s/MOTHERBD/S ... 3Rtc.shtml
In the "Integrated Peripherals" section of your BIOS setup, how are the following configured?
Onboard IDE Controller
Serial-ATA 0
SATA Mode Select
nVidia RAID Setup
FWIW, here are Vista drivers:
http://support.gateway.com/support/driv ... m=4006203R
