Forum rules
 Post subject: 3.5" desktop harddisk, max use how many "platters"
PostPosted: August 1st, 2010, 12:20
hi guys,
now that 3.5" desktop harddisk, max use how many "platters",
each "platters" max:500GB ?
in market, 500GB one platter found ?
and more than one platters that price is cheap? only ONE platter that price expensive?
one platter is very stable? and safe to keep data , no easy to damaged?
 Post subject: Re: 3.5" desktop harddisk, max use how many "platters"
PostPosted: August 1st, 2010, 17:29
you want to build your own hard drive?
Free Solutions
PostPosted: August 17th, 2010, 21:55
I think that platter density is already at 600GB per platter. One example is Seagate's 3TB FreeAgent GoFlex external drive.
According to this review ...
http://www.crunchgear.com/2010/07/01/ha ... ard-drive/
... the drive is a 7200 RPM, 3TB, Barracuda XT, model ST33000651AS. The "5" in the model number suggests that it has five 600GB platters.
Here is a close-up of the label:
http://www.crunchgear.com/wp-content/up ... -3tb-2.jpg
There are other drives that have a bit density per track that is consistent with a 600GB platter, but they are limited to 500GB per platter. You can see this in the maximum sustained data transfer rates. A 500GB density results in a performance score of ~130MB/s, whereas a drive with a 600GB density would score between 140 and 145 MB/s.
PostPosted: August 31st, 2010, 17:52
640GB/platter discs will be out soon/have just started releasing.
