Forum rules
 Post subject: Why Kingston micro SD cards are each of different size
PostPosted: October 25th, 2010, 12:16
When comparing with XP disk properties 2 different 2GB micro SD cards there is a weird difference 1,999,768,128 (1.83GB)
and other 1,999,800,896 (1.83)
When comparing to 3rd Kingston, not micro but 2GB mini SD -
the size appears to be les 1,999,175,680 (1.86GB)
What does it means that size is smaller but GB size is more then micro SD?
Thanks!
 Post subject: Re: Why Kingston micro SD cards are each of different size
PostPosted: October 25th, 2010, 12:21
Its the way flash memory is managed. You would need to read more on how flash works and "organises" files and the way it handles "bad blocks" .
Most good flash controllers control the flash memory in a dynamic method- making recovery from these beasts a pain in de backside some times.
There might be another cause to this to.. not sure
Free Solutions
