Power-on hours (SMART attrib) can be spoofed [ST3200822A]
But I don't know how it's being done.
[ST3200822A is a Seagate 200GB 7200.7 IDE]
I've had this drive in service for 6 years 24/7 under
heavy usage; never a problem. I thought: "Why not run a SMART report on it" so I installed it in a PC and did. Given its "stressful" life, I was not displeased that it had only 6 Reallocated_sectors, 0 Current_pending, and nothing else amiss. EXCEPT I noticed the Power_on_hours (raw value) was 1236. It should have been 50+K!
Further testing showed that,
outside of its normal setting, the POH functioned properly (1:1 w/wall clock), but when "on the job"
nada.
Is this a well-known fluke (and I'm the last to get the joke)?
[Note: I'm not trying to be coy by not describing its 24/7 environment--I'll follow-up with that, a little later. But I wanted to get learned response(s) prior to (possibly) prejudicing anyone.]
I've attached a [more] recent SMART report. Note +6 hours ([1242-1236] while it was in the PC) but there were 8 additional hours "on the job".
Puzzled,
UhClem
- Attachments
Sgt200-smart.txt
- (4.22 KiB) Downloaded 812 times
