Forum rules
 Post subject: Interpreting Oscilloscope Output
PostPosted: April 4th, 2011, 11:07
I used an Atola to run diagnostics on a hard drive. The following
link shows the oscilloscope output of the PCB during the power on
cycle of the drive.
http://ldf4n6.serveftp.net/images/HDD-Oscilloscope.jpg
The 12V reading is a flat line. I assume this means the PCB is having
power problems; however, I do hear the drive making abnormal grinding
like sounds.
Can someone elaborate on the interpretation of the oscilloscope output
and what it means?
 Post subject: Re: Interpreting Oscilloscope Output
PostPosted: April 4th, 2011, 12:21
From the current graph I can tell that this is probably a notebook drive, which means it does not need 12V. Furthermore, I can clearly see HDD spin up pattern on the 5V graph, and some attempts to initialize as well.
Dmitry
Users browsing this forum: No registered users and 90 guests
