Forum rules
 Post subject: Relation between DMA and AHCI technologies
PostPosted: June 15th, 2011, 5:16
Hello Everybody,
AHCI is defined as "a data movement engine between Memory and SATA devices". So DMA also acts as a "data movement engine between memory and storage devices". So, Is AHCI is enhanced version of DMA? Can anybody give me more clarification on this?
Aariyan
 Post subject: Re: Relation between DMA and AHCI technologies
PostPosted: June 15th, 2011, 5:25
I believe that AHCI enables NCQ support as well as hot-plug capability, Performace difference is negligible..
Steve..
http://www.eadr.co.uk
PostPosted: June 15th, 2011, 5:37
DMA is a protocol
AHCI is an interface
They not comparable
PostPosted: June 15th, 2011, 9:22
@Aariyan,
I agree with Doomer. Here are a few more comments...
No it isn't. :) You don't explain the source of this (misinformed) definition, but I suggest you read some more about AHCI, and read (at least some) of the specification itself:
http://www.intel.com/technology/serialata/ahci.htm
http://download.intel.com/technology/se ... rev1_3.pdf
A useful starting point for you, would be section 1.7 "Theory of Operation" in the AHCI spec v1.3 that I linked above.
No.
As an example: For part of its operation, an AHCI HBA uses DMA to access data in system memory, acting as a PCI bus master. However, as you will read in the specification, the AHCI specification defines much more than this.
Users browsing this forum: No registered users and 161 guests
