Forum rules
 Post subject: help me plzzzzz
PostPosted: October 10th, 2011, 18:59
i have hdd wd3200jb-00kfao with a fried pcb and the rom u12 is also fried i found a new pcb with the same no but when i tried it the hdd began to click so i need the right firmware for my drive , so please can you help
 Post subject: Re: help me plzzzzz
PostPosted: October 10th, 2011, 21:36
It seems that the drive has additional issues. It should have not clicked if it was just a pcb issue, given the pcb was compatible.
Do some search on preamp on the forum.
PostPosted: October 11th, 2011, 4:35
if it clicks and spindown can be also rom version mismatch with ATA module (mod11), you need proper tools to check it and fix it.
bye
Luca
Data Recovery pro in Italy
www.ultrarecovery.com
PostPosted: October 11th, 2011, 4:44
How do you know it is compatible? ROM contains no adaptive info, but ROM version should still match.
I agree. But is impossible to rule out preamp at this stage. But HDD powers donor PCB so this is good.
@m-zero What are full details of your HDD?
PostPosted: October 12th, 2011, 3:07
my hdd is wd3200jb-00kfao
i am sure that it is a rom version issue because the hard clicks and then spindown (shuts of)
the new pcb has the same numbers but it wasn't for the same drive (320 gb) so all i need is the firmware because rom chip is burnt and can't extract the firmware from it , if any one has the compatible firmware so i can dowbload it on the new pcb please .
and thanks 4 all of u
PostPosted: October 12th, 2011, 19:03
labtech wrote:
..., given the pcb was compatible.
ROM chip is burnt? That's unusual. Can you post a picture of your PCB?
PostPosted: October 12th, 2011, 20:26
Agree.
Roms usually works lower voltage than 5V, so usually stay good.
If your ROM is really burned, i think 99%, your preamp is gone as well.
Janos
PostPosted: October 13th, 2011, 15:43
don't any one have the firmware please ??????
PostPosted: October 15th, 2011, 3:51
Most of as have the needed firmware verion, but your drive have UNIQUE (exact drive specific) data on this PCB.
You _must_ transfer this information OR pay for a company who can re-create these information.
Without this, we can't help for you.
Janos
Users browsing this forum: No registered users and 97 guests
