Forum rules
 Post subject: UDMA CRC errors.
PostPosted: October 31st, 2011, 9:50
Hi there!
I'm currently trying to write a cloning software that use udma. I'm able to program the bus master to perform the transfer (on a vt6421a raid pci adapter). Everything works fine with sata, but with pata it's a different story. I get like 20% of the transactions ending up with crc errors. It seems to be related to the harddisk make (toshiba is 1/255 error, seagate and wd 20-40/255). It doesn't seem related to the type of pata to sata convertor or the cable. The timings on the hdd and the adapter were correctly programmed. I really need pata transfert as i would like to implement a hardware reset.
My questions are for those who have an experience in this type of programming:
-Is it normal to have such a high percentage of errors?
-Could it be related to the adapter (the via was chosen for the datasheet availability)
-How these errors must be handled? Repeat the 0x25 command until the transfert ends normally or ...
Thank you
 Post subject: Re: UDMA CRC errors.
PostPosted: October 31st, 2011, 10:32
In my experience with other PATA implementations, no.
You say that the percentage of I/O with CRC errors varies between HDD makes. This is typical behaviour for signal quality issues, so I suggest to investigate your "physical layer" electronics. If you are using SATA/PATA converters, then issues on the SATA link to a converter need to be considered, as well as issues on the PATA link itself. I can't sensibly give more detailed suggestions without having the config on a test bench in front of me. :(
PostPosted: October 31st, 2011, 10:55
Do you connect SATA directly to PATA connector or use cable?
Using correct cable? Have you tried a slower UDMA speed?
PostPosted: October 31st, 2011, 11:02
@Vorian: My thoughts about the SATA link above can probably be ignored, because if I understand you correctly, you are seeing different error rates with different PATA drives (using a SATA/PATA converter) - I presume you didn't change anything SATA-related during those tests.
Edited to add:
@guru: Agreed - those are some of the indirect changes which could be made, to try to infer a physical layer problem, if more direct measurement (e.g. using a high-speed oscilloscope) can't be done by the OP. :)
PostPosted: October 31st, 2011, 13:18
Thank you for your answers.
In fact I only tested sata drives on the sata end of the adapter with no error at all.
The problems arised when i connected drives (pata and sata) to the pata end of the vt6421. until UDMA33 they were no errors, above UDMA33 error rates varies from 1/255 (for a toshiba drive) to 20-40/255(for 2 seagates, 2wd and a samsung). I used the pata to sata convertor from my salvationdata dr (jmicron) and a 80 cable. I also tested another cheap converter, i changed the cable all these combinations gave the same error rate, so that left me with a/ bad pci adapter, b/ normal errors rate, c/?
I really doubted about b/ but I wanted to ask here to be sure. I'm gonna try another adapter...
@Vulcan: I have a 250mhz dso. Unfortunately it's a bit low to diagnose hardware problems on the ide bus.
PostPosted: October 31st, 2011, 14:30
Vorian wrote:
The problems arised when i connected drives (pata and sata) to the pata end of the vt6421. (My emphasis)
Based on these comments, I now see how the initial posting was ambiguous about exactly what was being connected where - I thought you first said everything was OK using SATA.
I'm too confused with the ambiguous descriptions, for it to be sensible making further comments or spending time on analysis :( Much clearer descriptions / photos / test scenarios & results are needed IMHO, to avoid wasted time & misunderstandings.
P.S. Even with limited bandwidth DSO, that doesn't mean the results of comparisons with "known good" are useless :)
Good luck!
PostPosted: October 31st, 2011, 15:24
I had some strange issues with SATA error rates in the past and a firmware update fixed the problem.
It's rather tricky if your making your own driver. I had quite good luck with HIGHPOINT cards in the past and docs can be found.
Linux drivers can help you grasp how to poke at the cards :O)
PostPosted: November 2nd, 2011, 10:42
It's seems I was not very clear, maybe I need to improve the way i write in English. Sorry for that, It's not my native language. Anyway, I found the error sources. I booted my computer using a msdos usb drive that wrote every packet read using the 0x25 command. When I didn't write these packets to usb drive, there were no crc errors. So I disabled usb and everything ran smoothly. Maybe a shared irq? I need to investigate further.
Thanks Vulcan and Guru for your advices
