Forum rules
 Post subject: Serial terminal pins on 2.5" IDE 5400.2 ?
PostPosted: August 2nd, 2010, 11:08
Can't seem to get any serial console output (Tx from disk) from the scrap 5400.2 drive I am playing with
Has 4 extra pins next to the 2.5" IDE connection
but none seem to be outputting any serial info on power up
Am I missing something obvious ?
(The cable I am using is good; or rather works ok on a couple of other different drives and so should be ok unless the signals/voltages are significantly different on this drive, which seems unlikely)
 Post subject: Re: Serial terminal pins on 2.5" IDE 5400.2 ?
PostPosted: August 2nd, 2010, 11:49
1- Check correct pinout. You can find it by Google.
2- Control Z brings up terminal
3- Terminal settings
4- Signal levels are 5 volt not RS232
Just some of the possibilities.
HWHacker
Smiles
PostPosted: August 2nd, 2010, 15:40
I'm having trouble confirming the correct pinout
You couldn't give me a hint could you
Looks like it isnt the 4 extra pins (which are on all makes of 2.5" ide for master/slave/CS)
PostPosted: August 3rd, 2010, 10:21
Try this
Seagate 5400.2 Pinout.pdf [85.73 KiB]
Downloaded 3202 times
HWHacker
Smiles
PostPosted: August 3rd, 2010, 12:11
But thats the SATA version
I'm trying to find out if the 2.5inch IDE version has serial terminal pins
PostPosted: August 21st, 2010, 5:07
If I were approaching this problem from first principles, the first thing I would do is to determine which, if any, of the 4 pins is Ground. I'm guessing it's the pin that is common to the CS and SL jumpers, ie bottom RH corner (when viewed with the IDE connector to the left). I would also measure the voltages at each of the pins, with jumpers removed. This should tell you whether you are dealing with 5V logic or 3.3V, or something else.
Assuming that the other two CS and SL pins are both inputs, and assuming that the I/O direction doesn't change after power-on, then the pin at the top LH corner would be an output, ie the drive's Tx pin.
It may be that the serial terminal needs to be enabled by placing a jumper, or jumpers, over certain pins during initial power-on. Afterwards the jumpers can be removed because the MCU doesn't need to examine them again.
PostPosted: August 21st, 2010, 18:42
finding the serial port is rather simple. Imagine trying to find Jtag !
PostPosted: August 22nd, 2010, 3:35
...or the joystick port...
PostPosted: August 23rd, 2010, 7:11
A message on another thread here by drc pointed be at the following
http://acelaboratory.com/pc3000.udma.php
The 2.5" adapter pcb has some very interesting silk screen printing and wiring for the terminal connection
Thanks drc !
NB I did try searching for the Tx (from the drive) for power-on messages, but couldn't find it
when I last tried
PostPosted: August 23rd, 2010, 7:31
LOL BlackST maybe we need seperate thread for joysticking your Seagate Terminal??
PostPosted: August 23rd, 2010, 8:30
Update to my message above
The adapter pcb indicates jumpers/connectors for terminal and/or factory mode related settings
PostPosted: August 18th, 2011, 15:12
Seagate Momentus ST94011A FW: 5.11
Looking at the back of the drive with the PCB at the bottom I have Tx&Rx connected to the rightmost bottom pins as well as having it jumpered for slave (top&bottom rightmost pins).
Hyperterminal is setup for 9600 8-N-1 no flow control.
Problem is when I powerup the drive I only get gibberish displayed in the terminal window?
Are my settings correct and should I be using any specific terminal emulation mode?
ú۪ʪº*띟›—)¿¿“¿;335755957¿åëcu_WUcu¿¥¿Aw-)¿¿¿¿£›•¿¿Ÿ¥åë{
        ¿¿¥¿›¥Ÿ—¿™
‹•“åëºú+õe+ëºj*ë¯_­_}W}¿[55åë
PostPosted: August 24th, 2011, 11:30
Looks like wrong baudrate. Try 38k4 or 115k2.
PostPosted: August 24th, 2011, 16:33
Check this link to see if it helps your situation: http://www.elektroda.pl/rtvforum/topic872300.html
PostPosted: August 26th, 2011, 9:30
Thanks, I'll try it again.
PostPosted: November 19th, 2011, 14:47
This looks like a very complicated schemantics, I use the schematics from the MAX3232 datasheet, and it works fine. It also supports 3.0V up to 5.0V, so it is compatible with my router and seagate and samsung hard drives.
PostPosted: November 20th, 2011, 20:16
Yes, but look at the date - the link is to a posting from 2007, and I'm fairly sure that the MAX3232 was only introduced a bit earlier that same year. So yes, now the MAX3232 is available - but before this existed, we were all using MAX232 etc. like in that schematic :) Also, that schematic shows a nice way to avoid needing an external power supply for the converter chip, so there are good reasons for its slight complexity IMHO.
PostPosted: December 10th, 2011, 13:02
Avoiding an external power supply is indeed, very nice. I had to build a weird construction to power mine. I also "fried" two MAX3232 in a row, because I did not pay attention how to plug in the power supply :( Luckily the IC is not that expensive.
