Forum rules
 Post subject: Selective Head Imagers and Head Fly-Height
PostPosted: December 7th, 2011, 7:25
Hello Experts
I have been researching hardware imagers that are capable of selective head imaging, and was just wondering a few things.
1. I believe some hard drives have adjustable head fly-height; is this a feature on most modern drives?
2. When a head is disabled (and it has adjustable fly-height), is its fly-height increased to maximum height to reduce likelihood of crashing?
Thanks in advance.
Cris
 Post subject: Re: Selective Head Imagers and Head Fly-Height
PostPosted: December 7th, 2011, 7:39
Cris wrote:
Hello Experts
Thanks in advance.
Cris
Interesting? Not heard of adjustable head fly height?
When the platters spin an air bearing is created that lifts the head just above the platters.
Loki
PostPosted: December 7th, 2011, 8:16
Flight height is determined by Preamplifier, I am not sure that there are any imagers that can control this, I do not know of one.
PostPosted: December 7th, 2011, 8:26
I assume the that preamp somehow measures the rpm & if thats in tolerance then in theory the heads will be at the correct height due to the air bearing that is created.
PostPosted: December 7th, 2011, 8:36
I was reading about Thermal Fly-height Control (TFC) Technology in Hitachi Hard Disk Drives:
http://www.hitachigst.com/tech/techlib. ... 041807.pdf
and thought maybe it was a common thing.
The real reason for asking is I was wondering why some of the literature implies it is safer to image with the good heads first, and then try with the faulty heads last. I first though it was because the faulty heads were at greater risk of crashing, but now I presume it is safer because it leaves the most strain intensive part of the imaging until last. Is that correct?
PostPosted: December 7th, 2011, 13:10
Has anyone ever tried running hard drives in different gas densities and monitoring: S.M.A.R.T. Attribute: Flying Height?
PostPosted: December 7th, 2011, 13:38
flying height is controlled by drive and it can be different for reading, writing and for each head in each zone
These parameters are written in adaptives, so drive does not increase flying height if head is disabled unless adaptives modified accordingly
PostPosted: December 7th, 2011, 14:18
Yes
PostPosted: December 7th, 2011, 22:04
Is it actually possible to increase the flying height?
IIUC, there is a heating coil that swells the slider in order to reduce the flying height. If you remove power from this heater, as would presumably be the case when this head was not reading or writing, then wouldn't the head just fly at its maximum height as determined by the air bearing?
PostPosted: December 7th, 2011, 22:15
That is what I was thinking.
