Forum rules
 Post subject: PLzz HeLp
PostPosted: October 13th, 2011, 0:34
I have formatted my hard disk can someone plz help me to get back my formatted data????
 Post subject: Re: PLzz HeLp
PostPosted: October 13th, 2011, 3:21
You should post on another area.
What happened after you format? What have you done? Installed anything?
PostPosted: October 13th, 2011, 7:10
I have formatted my C drive and want to get back the photos which i had saved there. I have upgraded from win xp to win 7 64 bit.
PostPosted: October 13th, 2011, 7:32
You say you formatted the C: & upgraded to win7 64 - I guess you mean you did a clean install. When you did the format was it quick or did it take ages? If it was quick then data recovery software should be able to recover some or most of your photos but the folder structure & names will be lost as the MFT has been over written. Do not write, install programs or save to the drive as you could ruin any chances of getting your data back by over writing the sectors. Also when did this happen? If it happend a while back & you have kept using win7 time is not your friend as I think win7 moves files to different sectors to optimize the os. Can anyone confirm this?
If it took ages to format then you will have lost your data as a win7 normal format writes zeros to the sectors over writing all data.
Loki
PostPosted: October 13th, 2011, 7:50
it happened last night. My friend told Win 7 has many features compared to xp. so installed win 7 and forgot to backup my pic's.
PostPosted: October 13th, 2011, 9:13
Loki
Yes, that is correct.
PostPosted: October 13th, 2011, 9:19
northwind wrote:
Loki
Thanks northwind for confirming that for me.
Loki
PostPosted: October 17th, 2011, 9:10
what is the solution for this problem???
PostPosted: October 17th, 2011, 9:37
Scan it with DMDE (NTFS search). It should find old system parameters.
data recovery Poland
PostPosted: November 26th, 2011, 0:17
How can you get back those formatted files? Formatting hard disc means you lost everything. Recovery is not possible. Some software’s are available in market, but I don’t know how worthy it is. Don’t you have a back up of those files? Hope it happened by mistake. Can you tell me what exactly happened here and what kind of files are you looking for? May be someone from the forum itself will be able to help you after reading the whole story.
PostPosted: December 19th, 2011, 9:21
if it the format is high leve, you can recover the data.
However you said that moved from XP to win7, you should have done a upgrade of the OS.
Users browsing this forum: No registered users and 90 guests
