Forum rules
 Post subject: which language uses harddisk to read & write the data
PostPosted: January 3rd, 2012, 5:54
can any friend give correct suggestion , which programming language helps to known about haddisk & datarecovery (for firmware ,SA,& to understand the how a harddisk reads the data & writes the data hexa decimal & system langauge)
 Post subject: Re: which language uses harddisk to read & write the data
PostPosted: April 26th, 2012, 21:37
The first, you must understand ATA standard. With programming language, you can use C/C++
Best Regards,
SkypID: hddselftest
Email: hddselftest@gmail.com
PostPosted: April 26th, 2012, 22:19
it is not related to programming language
PostPosted: April 26th, 2012, 23:59
You need to read the T10 & T13 documents to understand the standard HDD. For instance, if you want to know the HDD information, you can issue INQUIRY command for SCSI HDD. Programming just a languge how you code and is no related with HDD standard. Normally we will use C/C++.
T10:
http://www.t10.org/
T13:
http://t13.org/Default.aspx
PostPosted: April 27th, 2012, 12:12
You can use many different languages, C/C++/C#, Delphi, ASM, i have even seen some code for python for low level drive access.
