Forum rules
 Post subject: hardisk platter liquid solution used
PostPosted: June 17th, 2012, 14:33
what is the liquid solution used to make the platter more alive?
I ask that question because, I think I have erased the read/write platter raw data.
I've tried to touch the surface of the hard disk platter with a smooth cloth, wiping to make it shinny again
When I closed the hard disk cover and test, it's not responding anymore.
So, I'm asking for any idea, what are the possible liquid solution for the hard disk platter to make it active again.
I'm not concern about data recovery.
thanks :D
 Post subject: Re: hardisk platter liquid solution used
PostPosted: June 17th, 2012, 15:34
Let me think about that. I remember I used something one time and it worked.
PostPosted: June 17th, 2012, 23:58
It also worked when I put a computer cleaner, a bad odor with gas like solution, but that was a long time ago with 100mb hard disk :lol:
But now I'm very careful because this is not just mb, this is gb
thanks
PostPosted: June 18th, 2012, 3:08
I meant it's detected with same model and brand, with same size but during the use of hddtune quick test, all sectors are bad.
PostPosted: June 18th, 2012, 6:46
What is the drive's complete model?
PostPosted: June 18th, 2012, 13:05
by: fzabkar
Be aware that the bulk of the drive's firmware is stored in a hidden System Area on the platters
What the, whew, So, I destroyed the firmware? by touching the platter grounds, oh men.
The hardisk is seagate 160gig iDE
thanks
PostPosted: June 18th, 2012, 13:11
thanks
This does not mean complete model. The MDL spec will tell exactly the model. It is on the label on top of the drive.
Either way, if you can read the model and capacity and it is display in some sort of utility, then that is a promising sign.
Although can't exclude the possibility, I think the problem is likely to be with something other than the firmware.
Need pro help on this one. Recommend to no longer power the drive on and open its cover.
PostPosted: June 18th, 2012, 15:04
thanks :D
If datarecovery is not important dump this drive; the fact that this drive has been opened and you touched the platter with some tissue makes it unusable for datastorage.
Dobre
Murphy was an optimist
PostPosted: June 18th, 2012, 15:20
@labtec,
yes the hardisk is detected with exact brand and model, about formatting the drive, yes I'm beginning to format for now, BUT there are lots of loud noise, it's on its way to 2% using HDDGURU, and it's to slow, it's starts from 2.+mb/s to now it's 16.5mb/s, lol
What's funny upon formatting the drive, it stops for a while then continue to format, and so on, and I'm waiting when it's finished.
@dobrevjetser,
No, I have non left for buying another hardisk, lol
PostPosted: June 18th, 2012, 15:42
it's 12% on 10.5mb/s, and it's making a noise :D
PostPosted: June 18th, 2012, 15:47
This thread is a joke, right?
PostPosted: June 18th, 2012, 15:56
Haha, very funny topic :)
PostPosted: June 18th, 2012, 15:58
April fools day came late this year :-)
PostPosted: June 18th, 2012, 16:14
6/19/2012 3:11:45 AM =================================================
6/19/2012 3:11:45 AM HDD Low Level Format Tool 4.12; http://hddguru.com
6/19/2012 3:11:45 AM Low level format: [0] ST3160215A 3.AAD [160.04 GB]
6/19/2012 3:11:45 AM Device capacity: 312,579,695 sectors
6/19/2012 3:11:45 AM Locking device...
6/19/2012 3:11:45 AM Formatting...
6/19/2012 4:06:29 AM Format Error occurred at offset 24,914,755,584 (27)
What's number 27 error stands for?
PostPosted: June 18th, 2012, 16:22
Forget it. You killed this harddisk.
Dobre
PostPosted: June 19th, 2012, 14:39
assassinated it :mrgreen:
PostPosted: June 20th, 2012, 7:04
:shock:
PostPosted: June 20th, 2012, 10:14
Ok, the hardisk failed to finished the format.
But, I'll try to do it again, soon.
Probably a liquid without H2o and no Acid.
thanks
PostPosted: July 5th, 2012, 20:13
They used to sell PIXIE DUST which came in a spray can once
PostPosted: July 6th, 2012, 7:16
:lol: :mrgreen:
